소개
The DEEBOT model N97S did no longer hold a charge. Replacement batteries are sill readily found online and fairly easy to change,
필요한 것
Here is the DEEBOT DN622.11 also know as a N79S.
Turn it over to have the underside exposed
Locate the two Phillips head screws that hold the battery cover in place
거의 끝나갑니다!
To reassemble your Deebot, follow these instructions in reverse order.
결론
다른 2명이 해당 안내서를 완성하였습니다.
