주요 콘텐츠로 건너뛰기
Elastic Drawcord Replacement
필요한 것
  1. Elastic Drawcord Replacement, Assess the damage: 1 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Assess the damage: 1 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Assess the damage: 1 단계, 이미지 3개 중 3개
    • Assess the state of the drawcord - if it's damaged, stretched out, or missing entirely.
    • If original drawcord is present, take note of:
    • Design - How the drawcord is threaded into the garment (e.g. through hand pockets or a grosgrain loop)
    • Cord Lock - How the drawcord threads through the cord lock(s)
    • Other Pieces - If the drawcord is used with any additional hard trims like end caps or clear plastic discs
    • If the drawcord is missing entirely, please see Step 3.
  2. Elastic Drawcord Replacement, Remove the damaged drawcord: 2 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Remove the damaged drawcord: 2 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Remove the damaged drawcord: 2 단계, 이미지 3개 중 3개
    • On both ends of the drawcord:
    • Use flush cutters to pry off the tip of the end cap.
    • Pull the drawcord end out of the end cap and untie the knot.
    • Remove the base of the end cap and any plastic discs (if present).
    • Wear safety glasses.
    • Save all these pieces.
    • Unthread the drawcord by releasing the tension from the cord locks and pulling it out of the garment completely.
    • The drawcord end knots can also be cut for faster removal (reference image #2). If doing so, add 1 inch (~25 mm) to the measurement in Step 3.
  3. Elastic Drawcord Replacement, Measure and cut the new drawcord: 3 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Measure and cut the new drawcord: 3 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Measure and cut the new drawcord: 3 단계, 이미지 3개 중 3개
    • If the drawcord isn't stretched out or missing any part, use the old drawcord as a reference to measure and cut the appropriate length for a new one.
    • Alternatively, to measure and cut a new drawcord without the old one:
    • Measure the length of the hem.
    • Add the distance the cord travels to and from any cord locks.
    • Add 2 inches (~51 mm) to account for a 1 inch (~25 mm) seam allowance on each end.
    • Add an additional 1 inch (~25 mm) if the drawcord end knots were cut in Step 2.
    • Use a lighter to singe the cut ends of the drawcord.
    • Discard broken pieces responsibly.
  4. Elastic Drawcord Replacement, Thread the drawcord into the hem: 4 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Thread the drawcord into the hem: 4 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Thread the drawcord into the hem: 4 단계, 이미지 3개 중 3개
    • Use your fingers or a plastic drawstring threader to thread the new drawcord through the hem.
    • Once through the hem, double check that the drawcord length is correct.
    • Thread the drawcord through any cord locks and associated grosgrain tabs.
  5. Elastic Drawcord Replacement, Thread the drawcord into pockets: 5 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Thread the drawcord into pockets: 5 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Thread the drawcord into pockets: 5 단계, 이미지 3개 중 3개
    • Use a plastic drawstring threader, latch hook, bodkin, or safety pin to thread the drawcord ends into pockets.
  6. Elastic Drawcord Replacement, Secure the new drawcord: 6 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Secure the new drawcord: 6 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Secure the new drawcord: 6 단계, 이미지 3개 중 3개
    • Thread the plastic disc and the end cap base onto the drawcord end.
    • Tie a knot at the end of the drawcord. Pull it tight and snip or singe away any excess.
    • Pull the drawcord so the knot rests inside the end cap base.
    • Check that the knot doesn't pull through the end cap.
    • Replace end cap tip by snapping it into place.
  7. Elastic Drawcord Replacement, Functionality test and quality control: 7 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Functionality test and quality control: 7 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Functionality test and quality control: 7 단계, 이미지 3개 중 3개
    • Pull on the ends of the drawcord to make sure they're secured and that the drawcord is functioning properly.
    • Test the drawcord's function at each cord lock.
    • Make a final check on the drawcord length when the cord locks are loosened and the drawcord is laying naturally:
    • Too Tight - Not enough cord. The hemline will bunch.
    • Too Loose - Too much cord. Excess drawcord will either undulate inside the hemline or hang loosely from the cord locks.
  8. Elastic Drawcord Replacement, Troubleshooting: 8 단계, 이미지 3개 중 1개 Elastic Drawcord Replacement, Troubleshooting: 8 단계, 이미지 3개 중 2개 Elastic Drawcord Replacement, Troubleshooting: 8 단계, 이미지 3개 중 3개
    • VARIATIONS: There are many varieties of drawcords on the vast array of Patagonia items. The techniques and steps outlined in this tutorial can be rearranged or modified to fit the circumstances.
    • MISSING CORD: If the drawcord is missing entirely, use grosgrain loops, eyelets and rivets as context clues. Alternatively, try to find photos of the item on Patagonia.com, WornWear.com, and Google image search.
    • HOOD: Hood drawcords can be more complex with multiple lengths of elastic that can loop around one another. Be careful to examine the placement of drawcords in a hood before removing them.
결승점
작성자
2다른 기여자 명과 함께
Katherine Anick-Jenkins
회원 가입일: 12/18/24
157 평판
안내서 1개를 작성함
Patagonia Patagonia 회원
Community
17 회원들
안내서 168개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 37
지난 7일: 316
지난 30일: 1,062
전체 시간: 3,153
