주요 콘텐츠로 건너뛰기
Electrical Plug Replacement
필요한 것
  1. Electrical Plug Replacement, Two-Pole Plug: 1 단계, 이미지 2개 중 1개 Electrical Plug Replacement, Two-Pole Plug: 1 단계, 이미지 2개 중 2개
    • Be sure to unplug the lamp.
    • Locate the damaged portion of wire.
    • Cut the damaged plug from the lamp cord one inch below the damaged area
  2. Electrical Plug Replacement: 2 단계, 이미지 2개 중 1개 Electrical Plug Replacement: 2 단계, 이미지 2개 중 2개
    • Separate the wire by gently pulling it apart.
    • The wire with the raised ribbing on the coating is the neutral wire.
    • The hot wire has a smooth coating.
  3. Electrical Plug Replacement: 3 단계, 이미지 3개 중 1개 Electrical Plug Replacement: 3 단계, 이미지 3개 중 2개 Electrical Plug Replacement: 3 단계, 이미지 3개 중 3개
    • Strip the coating off the wire.
    • Expose 3/4" of the copper wire.
    • Twist the exposed copper wire so that there is no fraying.
    • Twisting the wires ensures the strongest connection and maximum safety.
  4. Electrical Plug Replacement: 4 단계, 이미지 2개 중 1개 Electrical Plug Replacement: 4 단계, 이미지 2개 중 2개
    • Loosen the screw and open the replacement plug.
    • The silver screw is the neutral connection, and the brass screw is the hot connection.
    • The different connections must be determined in order to properly wire the replacement plug.
  5. Electrical Plug Replacement: 5 단계, 이미지 3개 중 1개 Electrical Plug Replacement: 5 단계, 이미지 3개 중 2개 Electrical Plug Replacement: 5 단계, 이미지 3개 중 3개
    • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
    • Remember the neutral wire is the wire with raised ribbing on the coating.
    • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  6. Electrical Plug Replacement: 6 단계, 이미지 2개 중 1개 Electrical Plug Replacement: 6 단계, 이미지 2개 중 2개
    • Thread the cord so the plug will completely close.
    • Tighten the exterior screw to close the plug.
    Where can I purchase a new plug
    Marlene4950 - 답글
    You can purchase it at almost every hardware store.
    Toon Konings - 답글
결론
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Tim Spellings
회원 가입일: 07/17/15
571 평판
안내서 1개를 작성함
Texas Tech, Team 3-2, Rauch SU 2015 Texas Tech, Team 3-2, Rauch SU 2015 회원
TTU-RAUCH-SU15S3G2
3 회원들
안내서 4개를 작성함
댓글 7개
Passt - gute Anleitung
Martin Winter - 답글
A version for 3 prong (North American) would be great
James Harrison - 답글
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - 답글
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - 답글
Buy a plug that can be opened with a screw
Toon Konings -
How can you tell hot wire from neutral wire?
Dr. Karakas - 답글
the neutral wire usually has raised ribbing on its sleeve, and the hot wire has a smooth rubber sleeve. (See Step 2 of the guide)
Ben Eccles -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 54
지난 30일: 324
전체 시간: 49,227
