주요 콘텐츠로 건너뛰기
Electro-Harmonix Bass Mono Synth Wiring Repair
필요한 것
  1. Electro-Harmonix Bass Mono Synth Wiring Repair, Electro-Harmonix Bass Mono Synth Wiring Repair: 1 단계, 이미지 1/2 Electro-Harmonix Bass Mono Synth Wiring Repair, Electro-Harmonix Bass Mono Synth Wiring Repair: 1 단계, 이미지 2/2
    • Gently pry the five knobs with an opening tool until they are loose.
    • Once the knobs are loose, gently pull them off.
    • Be careful not to scratch or damage the pedal's paint.
  2. Electro-Harmonix Bass Mono Synth Wiring Repair: 2 단계, 이미지 1/2 Electro-Harmonix Bass Mono Synth Wiring Repair: 2 단계, 이미지 2/2
    • Using the adjustable wrench, loosen the hex nuts by turning them counterclockwise.
    • Once the hex nuts are loose, remove them and their washers by hand.
    • Remember to keep each size of hex nut and washer separate for easy reassembly.
  3. Electro-Harmonix Bass Mono Synth Wiring Repair: 3 단계, 이미지 1/2 Electro-Harmonix Bass Mono Synth Wiring Repair: 3 단계, 이미지 2/2
    • Using the adjustable wrench, remove the hex nuts from the stomp buttons.
    • The stomp buttons will become loose as the hex nuts are removed.
  4. Electro-Harmonix Bass Mono Synth Wiring Repair: 4 단계, 이미지 1/3 Electro-Harmonix Bass Mono Synth Wiring Repair: 4 단계, 이미지 2/3 Electro-Harmonix Bass Mono Synth Wiring Repair: 4 단계, 이미지 3/3
    • Using the adjustable wrench, remove the hex nuts and their washers from the left and right sides of the pedal.
  5. Electro-Harmonix Bass Mono Synth Wiring Repair: 5 단계, 이미지 1/3 Electro-Harmonix Bass Mono Synth Wiring Repair: 5 단계, 이미지 2/3 Electro-Harmonix Bass Mono Synth Wiring Repair: 5 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove all four screws from the back of the device.
    • Remove the back plate from the pedal.
  6. Electro-Harmonix Bass Mono Synth Wiring Repair: 6 단계, 이미지 1/3 Electro-Harmonix Bass Mono Synth Wiring Repair: 6 단계, 이미지 2/3 Electro-Harmonix Bass Mono Synth Wiring Repair: 6 단계, 이미지 3/3
    • The motherboard will be loose at this step except for the 9V power port which is snug in the case.
    • Using an opening tool, push or pry the 9V power port free of the case.
    • Gently remove the motherboard.
    • The stomp buttons will be loose at this step, so remember where they came from.
  7. Electro-Harmonix Bass Mono Synth Wiring Repair: 7 단계, 이미지 1/1
    • Put on personal protective equipment. This includes safety goggles, gloves, and closed toed shoes.
    • Using the soldering tool, solder the damaged connections of the I/O jacks on the bottom of the motherboard.
    • If you have no experience with soldering, follow this guide.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Augustine Barr
회원 가입일: 09/08/21
163 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 360
