주요 콘텐츠로 건너뛰기
Element GC-1020 Battery Replacement
필요한 것
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: 1 단계, 이미지 1/1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: 2 단계, 이미지 1/1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: 3 단계, 이미지 1/2 Element GC-1020 Battery  Replacement, Battery: 3 단계, 이미지 2/2
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lashaun Noel
회원 가입일: 09/25/15
591 평판
안내서 5개 작성하였습니다
University of Tampa, Team 1-4, Whiteside Fall 2015 University of Tampa, Team 1-4, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 12
전체 시간: 331
