주요 콘텐츠로 건너뛰기
Ematic FunTab 2 Motherboard Replacement
필요한 것
  1. Ematic FunTab 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
  2. Ematic FunTab 2 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Next, you need to remove all connections to the motherboard and the device.
    • Start by first removing the tape from all the connections.
    • Be careful not to remove the camera.
  3. Ematic FunTab 2 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove LCD connector from the LCD.
    • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
  4. Ematic FunTab 2 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove camera connection from camera with tweezers.
    • Again, be sure to flip up the retaining tab before pulling the connector.
  5. Ematic FunTab 2 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove speaker connection from speaker with tweezers.
    • Before pulling the speaker connection make sure the retaining tab is flipped up.
  6. Ematic FunTab 2 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Remove wires:
    • Start by removing the black wire on each side.
    • Next, remove the WiFi antenna wire from the motherboard.
    • Finally, remove the yellow, red, and black wires.
    • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder 연결부 납땜 및 납제거 방법
  7. Ematic FunTab 2 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
    • All of the screws are the same size, and should all fit in either corresponding screw location.
  8. Ematic FunTab 2 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Ematic FunTab 2 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • It is now safe to remove and replace the old motherboard with your new motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Amanda Wolosz
회원 가입일: 04/05/15
287 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 1,253
