주요 콘텐츠로 건너뛰기
Ematic FunTab 3 Speaker Replacement
필요한 것
  1. Ematic FunTab 3 Speaker Replacement, Back Panel: 1 단계, 이미지 1/3 Ematic FunTab 3 Speaker Replacement, Back Panel: 1 단계, 이미지 2/3 Ematic FunTab 3 Speaker Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Speaker Replacement: 2 단계, 이미지 1/1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Speaker Replacement, Speaker: 3 단계, 이미지 1/2 Ematic FunTab 3 Speaker Replacement, Speaker: 3 단계, 이미지 2/2
  4. Ematic FunTab 3 Speaker Replacement: 4 단계, 이미지 1/3 Ematic FunTab 3 Speaker Replacement: 4 단계, 이미지 2/3 Ematic FunTab 3 Speaker Replacement: 4 단계, 이미지 3/3
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
결론
Amanda Davis
회원 가입일: 07/11/18
581 평판
안내서 5개 작성하였습니다
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G5
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 192
