주요 콘텐츠로 건너뛰기
Envizen V100M Battery Replacement
필요한 것
  1. Envizen V100M Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Envizen V100M Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Battery Replacement: 2 단계, 이미지 1/3 Envizen V100M Battery Replacement: 2 단계, 이미지 2/3 Envizen V100M Battery Replacement: 2 단계, 이미지 3/3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Battery Replacement, Battery: 3 단계, 이미지 1/3 Envizen V100M Battery Replacement, Battery: 3 단계, 이미지 2/3 Envizen V100M Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Remove the non-conductive tape located on the battery and motherboard assembly.
  4. Envizen V100M Battery Replacement: 4 단계, 이미지 1/3 Envizen V100M Battery Replacement: 4 단계, 이미지 2/3 Envizen V100M Battery Replacement: 4 단계, 이미지 3/3
    • Slide the ifixit spudger under the battery, and work down the side of the battery, releasing it from the adhesive holding it down.
    • Remove battery from the Envizen V100M.
  5. Envizen V100M Battery Replacement: 5 단계, 이미지 1/1
    • Remove the solder from the red and black wires from the battery attached to the motherboard. Here is a guide on how to solder.
    • Remove the red and black wire from the motherboard using tweezers. If tweezers are unable to remove the wires, heat can be used to loosen the solder allowing for the wires to be removed.
  6. Envizen V100M Battery Replacement: 6 단계, 이미지 1/1
    • Remove the black and white wires from the motherboard. These wires power the LCD screen. Remove the black and white wires by first trying tweezers and if difficult use heat to loosen the solder allowing for the removal of the wires.
    • Note during final installation remember to match the location of the black and white wires to the picture
결론
다른 한 분이 해당 안내서를 완성하였습니다.
nbach
회원 가입일: 03/23/15
663 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-2, Duarte Spring 2015 UMass Dartmouth, Team 3-2, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 1,599
