이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
