주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
부품
지정된 부품이 없습니다.
  1. remove the battery door using either your finger nail or a screwdriver. remove the battery door using either your finger nail or a screwdriver. remove the battery door using either your finger nail or a screwdriver.
    • remove the battery door using either your finger nail or a screwdriver.
  2. Then remove the three screws on the back cover using a philips screwdriver #1. Then remove the three screws on the back cover using a philips screwdriver #1.
    • Then remove the three screws on the back cover using a philips screwdriver #1.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Remove the black back cover with your hand and be careful not to cut the wires attached on the cover.
    • Remove the black back cover with your hand and be careful not to cut the wires attached on the cover.
  5. Using a screwdriver #1, remove the 2 small screws located at the top and bottom of the alarm switch. Using a screwdriver #1, remove the 2 small screws located at the top and bottom of the alarm switch.
    • Using a screwdriver #1, remove the 2 small screws located at the top and bottom of the alarm switch.
  6. Using soldering iron, detach wire end from the copper cylinder by plaint the end of the iron to the end of the wire. Now you can replace the alarm switch with a new one by attaching one end of the wires to the copper cylinder . Then install the switch screws using the screwdriver. Using soldering iron, detach wire end from the copper cylinder by plaint the end of the iron to the end of the wire. Now you can replace the alarm switch with a new one by attaching one end of the wires to the copper cylinder . Then install the switch screws using the screwdriver.
    • Using soldering iron, detach wire end from the copper cylinder by plaint the end of the iron to the end of the wire. Now you can replace the alarm switch with a new one by attaching one end of the wires to the copper cylinder . Then install the switch screws using the screwdriver.
  7. a photo of the steps we have been through in working on the clock and a photo of the tools we used and the clock parts during disassembly a photo of the steps we have been through in working on the clock and a photo of the tools we used and the clock parts during disassembly
    • a photo of the steps we have been through in working on the clock and a photo of the tools we used and the clock parts during disassembly
결론
Alaa
회원 가입일: 2014년 10월 27일
228 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 522
