주요 콘텐츠로 건너뛰기
Ergomixx Blender (Bosch) disassembly
필요한 것
  1. Ergomixx Blender (Bosch) disassembly, Head Screws: 1 단계, 이미지 1/1
    • The speed switch can be removed by placing it on position 3 (to be checked, we broke it without realizing it) and then pulling the switch out.
    • The 2 first screws are now visible.
  2. Ergomixx Blender (Bosch) disassembly, Case screws: 2 단계, 이미지 1/1
    • The last 2 screws are hidden under a small plastic cover at the bottom of the motor block.
  3. Ergomixx Blender (Bosch) disassembly, GR Thermal Micro-switch: 3 단계, 이미지 1/1
    • In our case, the thermal fuse was blown, i.e. the small white component labelled «Y51 H 120C».
    • First solution: remove the thermal fuse and place a shunt instead (a small wire). Downside: loss of the thermal protection on this "short working duration" blender.
    • Second solution: replace the thermal fuse (which is better) by a component with the same characteristics. In this case, probably with a fusing temperature of 120°C and a max. current 5A.
    • Thanks to Darr and to webpage http://elwo.ru/forum/34-1408-1 for the picture and for giving us the right hint.
결론
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Louis Possoz
회원 가입일: 01/10/15
435 평판
안내서 3개 작성하였습니다
Repair Café Louvain-la-Neuve Repair Café Louvain-la-Neuve 회원
Local Repair Groups
2 회원들
안내서 6개 작성하였습니다
댓글 3개
Avant tout Merci beaucoup pour ce tutoriel!
Il m’a vraiment bien servi.
Je confirme que la bonne position, pour retirer le bouton du régulateur de vitesse, est 2 ( et non 3 ).
Il faut malgré tout le retirer délicatement ( j’ai aussi cassé pour avoir tiré trop fort )
Cordialement
Lionel
Cachou - 답글
Merci pour la procédure d'ouverture, mais malheureusement trop courte! Il faudrait y ajouter les 4 zones d'appui (2 par coté de jonction) pour savoir ou pousser exactement afin de libérer les verrouillages d'emboitement. J'ai pris énormément de temps pour ces zones et en douceur, j'ai réussi a libérer ces 2 pattes pour permettre l'ouverture dans la zone centrale du moteur. Personnellement c'était un fil d'alimentation cassé juste à la fin de la gaine de maintien en sortie d'appareil. panne classique si on enroule trop court le fil autour du mixeur.
Bref au total 3h pour réparer ce fil d'alimentation. (raccourci juste à la cassure)
Merci pour votre tuto
GHISLAIN DUFRANE - 답글
Bonjour @ghislaindufrane C'est un plaisir d'entendre que vous avez réussi à réparer votre mixeur ! Félicitations et merci également pour le précieux retour. iFixit étant un wiki, je vous invite à mettre à jour le tutoriel pour que les suivants puissent réparer encore plus facilement. La communauté vous sera infiniment reconnaissante !
Claire Miesch -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 31
30일 전: 137
전체 시간: 13,930
