소개
The Eton Soulra XL has two woofers that are relatively easy to access and reconnect, should one become disconnected. This guide will provide step-by-step instructions to disassemble, clean, and repair loose connections. You will need to know how to solder; review How To Solder and Desolder Connections if you are unfamiliar with the process.
필요한 것
Gently pull down and out on the front cover; it should come off easily.
다른 2명이 해당 안내서를 완성하였습니다.
