주요 콘텐츠로 건너뛰기
Fahrenheit FHT 125PRMR Dial Replacement
필요한 것
  1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: 1 단계, 이미지 1개 중 1개
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Dial Replacement: 3 단계, 이미지 2개 중 1개 Fahrenheit FHT 125PRMR Dial Replacement: 3 단계, 이미지 2개 중 2개
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Dial Replacement: 4 단계, 이미지 2개 중 1개 Fahrenheit FHT 125PRMR Dial Replacement: 4 단계, 이미지 2개 중 2개
    • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
  5. Fahrenheit FHT 125PRMR Dial Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
  6. Fahrenheit FHT 125PRMR Dial Replacement: 6 단계, 이미지 2개 중 1개 Fahrenheit FHT 125PRMR Dial Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
    • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
  7. Fahrenheit FHT 125PRMR Dial Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Dial Replacement: 8 단계, 이미지 1개 중 1개
결론
작성자
1다른 기여자 명과 함께
Nicolas Moreau
회원 가입일: 09/29/16
180 평판
안내서 1개를 작성함
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 회원
IUPUI-HARLEY-F16S2G2
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 20
전체 시간: 889
