이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The second step is to take out the little screw on the back side of the key.
You will push the buttons from the front side to have the middle piece fall out.
Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
