주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Floppy Disk 수리는 저희 서비스 설명서를 사용하십시오.
  1. Floppy Disk Teardown, Floppy Disk Teardown: 1 단계, 이미지 1/2 Floppy Disk Teardown, Floppy Disk Teardown: 1 단계, 이미지 2/2
    • The floppy disk has gone the way of the dinosaur.
    • Except for Google's lovable jumping dinosaur.
    • These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
    • It's worth noting that today's photos taken can be upwards of 10MB on their own!
    • We liked skimmilk05's teardown so much (and his amazing attempt at his own teardown graphic) we supplied one of our own for this truly unique community contributed teardown. - iFixit Staff <3
  2. Floppy Disk Teardown, Removing the Cover: 2 단계, 이미지 1/2 Floppy Disk Teardown, Removing the Cover: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Jimmy
    $7.95
    구매
    • Thin metal pieces are good places to start.
    • This one's so thin that you can bend it with a finger.
    • This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
  3. Floppy Disk Teardown, Removing the Casing: 3 단계, 이미지 1/3 Floppy Disk Teardown, Removing the Casing: 3 단계, 이미지 2/3 Floppy Disk Teardown, Removing the Casing: 3 단계, 이미지 3/3
    • With some careful prying, the entire lid pops right off.
    • You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
    • There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • And we get a glimpse of what's inside! Spoiler alert: not much is there.
  4. Floppy Disk Teardown, The Spring: 4 단계, 이미지 1/1
    • In cracking open the casing, we lost a tiny little spring.
    • Boing.
    • Boing.
    • Playtime's over. Best guess as to what it is? Keeping that metal piece over the tape inside.
  5. Floppy Disk Teardown, The Cleaning Pad: 5 단계, 이미지 1/1
    • On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • This one was pretty nasty. Eww.
    • This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
    • Aha!
    • The meat n' bones of the floppy disk, the disk itself!
    • Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
  6. Floppy Disk Teardown, The Disk: 7 단계, 이미지 1/2 Floppy Disk Teardown, The Disk: 7 단계, 이미지 2/2
    • More floppy goodness.
  7. Floppy Disk Teardown, Wrap-up: 8 단계, 이미지 1/1
    • It's a pretty simple device in all. Not much else to say here.
  8. Floppy Disk Teardown, Final Thoughts: 9 단계, 이미지 1/2 Floppy Disk Teardown, Final Thoughts: 9 단계, 이미지 2/2
    • Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • This antique technology has virtually no replacement parts.
    • Replacement of the tape or cleaning pads are impossible without breaking the case.
    • The cleaning pads are held on with tight adhesive, making replacement difficult.
    • Attempts to use heat to loosen adhesive may result in the case melting.
    • High susceptibility to magnets make this device very sensitive.
Seji the veggie
회원 가입일: 02/09/15
1,986 평판
안내서 1개 작성함
댓글 10개
Super cool! Haven't seen a floppy disk in forever.
Taylor Whitney - 답글
They are a tad old...haha
Seji the veggie -
This is amazeballs. Solid work!
Kay-Kay Clapp - 답글
"floppy goodness" -- so good
Julia - 답글
Great teardown! :)
Jeff Suovanen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 51
전체 시간: 10,506
