주요 콘텐츠로 건너뛰기
FoodSaver V4980 Bag Cutter Replacement
  1. FoodSaver V4980 Bag Cutter Replacement, Bag Cutter: 1 단계, 이미지 1/1
    • The bag cutter is a small plastic rolling apparatus in the bag cutter arm.
    • Lift up the top cover to get to the bag cutter arm.
  2. FoodSaver V4980 Bag Cutter Replacement: 2 단계, 이미지 1/2 FoodSaver V4980 Bag Cutter Replacement: 2 단계, 이미지 2/2
    • Pull the sides of the cutter arm apart, and pull on the bag cutter to remove it from the arm.
결론
Mackenzie Grossgold
회원 가입일: 04/14/16
940 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-17, Maness Spring 2016 Cal Poly, Team 34-17, Maness Spring 2016 회원
CPSU-MANESS-S16S34G17
4 회원들
안내서 6개 작성하였습니다
댓글 3개
how do i get a new one
Darlene Paulson - 답글
my bag cutter dont cut how do i get a new one & how much
my MACHINE IS BRAND NE, FIRST USE AND IT WILL NOT CUT
James Budelman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 37
전체 시간: 3,549
