주요 콘텐츠로 건너뛰기
Framework Laptop 12 Display Cover Replacement
필요한 것
  1. Framework Laptop 12 Display Cover Replacement, Open your laptop: 1 단계, 이미지 2개 중 1개 Framework Laptop 12 Display Cover Replacement, Open your laptop: 1 단계, 이미지 2개 중 2개
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  2. Framework Laptop 12 Display Cover Replacement, Remove the Display Cover: 2 단계, 이미지 2개 중 1개 Framework Laptop 12 Display Cover Replacement, Remove the Display Cover: 2 단계, 이미지 2개 중 2개
    • The Display Cover is held in place with magnets along the top edge and clips along the remaining edges.
    • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
  3. Framework Laptop 12 Display Cover Replacement: 3 단계, 이미지 3개 중 1개 Framework Laptop 12 Display Cover Replacement: 3 단계, 이미지 3개 중 2개 Framework Laptop 12 Display Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
  4. Framework Laptop 12 Display Cover Replacement: 4 단계, 이미지 2개 중 1개 Framework Laptop 12 Display Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the Display Cover.
  5. Framework Laptop 12 Display Cover Replacement, Disassembly complete: 5 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  6. Framework Laptop 12 Display Cover Replacement, Install the Display Cover: 6 단계, 이미지 2개 중 1개 Framework Laptop 12 Display Cover Replacement, Install the Display Cover: 6 단계, 이미지 2개 중 2개
    • Align the Display Cover to the bottom of the display.
  7. Framework Laptop 12 Display Cover Replacement: 7 단계, 이미지 2개 중 1개 Framework Laptop 12 Display Cover Replacement: 7 단계, 이미지 2개 중 2개
    • Use your finger to press along the length of the Display Cover to snap it onto the laptop.
    • Make sure all the clips along the left, top, and right edges are fully seated.
결론
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,613 평판
안내서 701개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 175
