주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Framework Laptop 12 Input Cover Replacement
필요한 것
  1. Framework Laptop 12 Input Cover Replacement, Power down your laptop: 1 단계, 이미지 3개 중 1개 Framework Laptop 12 Input Cover Replacement, Power down your laptop: 1 단계, 이미지 3개 중 2개 Framework Laptop 12 Input Cover Replacement, Power down your laptop: 1 단계, 이미지 3개 중 3개
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Input Cover Replacement, Set your laptop down: 2 단계, 이미지 1개 중 1개
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Input Cover Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 1개 Framework Laptop 12 Input Cover Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 Input Cover Replacement, Flip your laptop over: 4 단계, 이미지 1개 중 1개
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Input Cover Replacement, Open your laptop: 5 단계, 이미지 2개 중 1개 Framework Laptop 12 Input Cover Replacement, Open your laptop: 5 단계, 이미지 2개 중 2개
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Input Cover Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 1개 Framework Laptop 12 Input Cover Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 2개 Framework Laptop 12 Input Cover Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 3개
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Input Cover Replacement, Disassembly complete: 7 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  8. Framework Laptop 12 Input Cover Replacement, Install the Input Cover: 8 단계, 이미지 3개 중 1개 Framework Laptop 12 Input Cover Replacement, Install the Input Cover: 8 단계, 이미지 3개 중 2개 Framework Laptop 12 Input Cover Replacement, Install the Input Cover: 8 단계, 이미지 3개 중 3개
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  9. Framework Laptop 12 Input Cover Replacement, Close and flip your laptop: 9 단계, 이미지 2개 중 1개 Framework Laptop 12 Input Cover Replacement, Close and flip your laptop: 9 단계, 이미지 2개 중 2개
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  10. Framework Laptop 12 Input Cover Replacement, Tighten the bottom screws: 10 단계, 이미지 2개 중 1개 Framework Laptop 12 Input Cover Replacement, Tighten the bottom screws: 10 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
결론
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
335,846 평판
안내서 848개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 17,794개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 56
전체 시간: 749
