주요 콘텐츠로 건너뛰기
Framework Laptop 16" Webcam Module Replacement
필요한 것
  1. Framework Laptop 16" Webcam Module Replacement, Before you begin: 1 단계, 이미지 2개 중 1개 Framework Laptop 16" Webcam Module Replacement, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Webcam Module Replacement, Create a gap: 2 단계, 이미지 3개 중 1개 Framework Laptop 16" Webcam Module Replacement, Create a gap: 2 단계, 이미지 3개 중 2개 Framework Laptop 16" Webcam Module Replacement, Create a gap: 2 단계, 이미지 3개 중 3개
    • The bezel is secured with magnets!
    • Slide your fingernail under the inside edge of either bottom corner of the bezel.
    • Pull the bezel away from the screen to release the first few magnets.
  3. Framework Laptop 16" Webcam Module Replacement, Remove the bezel: 3 단계, 이미지 3개 중 1개 Framework Laptop 16" Webcam Module Replacement, Remove the bezel: 3 단계, 이미지 3개 중 2개 Framework Laptop 16" Webcam Module Replacement, Remove the bezel: 3 단계, 이미지 3개 중 3개
    • Lift the bezel around the perimeter of the screen until all of its magnets are released.
    • Remove the bezel.
  4. Framework Laptop 16" Webcam Module Replacement, Disconnect the webcam module: 4 단계, 이미지 2개 중 1개 Framework Laptop 16" Webcam Module Replacement, Disconnect the webcam module: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the webcam module ZIF connector.
  5. Framework Laptop 16" Webcam Module Replacement, Remove the webcam module screws: 5 단계, 이미지 3개 중 1개 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module screws: 5 단계, 이미지 3개 중 2개 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module screws: 5 단계, 이미지 3개 중 3개
    • Use a T5 Torx screwdriver to remove the two 2 mm‑long screws securing the webcam module.
    • The screws thread through metal brackets. If they come off with the screws, you can skip the next step.
    • During reassembly, support the screen frame with your other hand as you reinsert screws to prevent the laptop from accidentally tipping over.
  6. Framework Laptop 16" Webcam Module Replacement: 6 단계, 이미지 3개 중 1개 Framework Laptop 16" Webcam Module Replacement: 6 단계, 이미지 3개 중 2개 Framework Laptop 16" Webcam Module Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the two metal brackets on both ends of the webcam module.
  7. Framework Laptop 16" Webcam Module Replacement, Remove the webcam module: 7 단계, 이미지 3개 중 1개 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module: 7 단계, 이미지 3개 중 2개 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module: 7 단계, 이미지 3개 중 3개
    • Use tweezers to lift the right side of the webcam module until the cable slides out of the ZIF connector.
    • Remove the webcam module.
  8. Framework Laptop 16" Webcam Module Replacement, Reassembly information: 8 단계, 이미지 3개 중 1개 Framework Laptop 16" Webcam Module Replacement, Reassembly information: 8 단계, 이미지 3개 중 2개 Framework Laptop 16" Webcam Module Replacement, Reassembly information: 8 단계, 이미지 3개 중 3개
    • Reconnecting the webcam module is a little tricky. If you're having difficulty, you can reposition the display to give the webcam cable more slack.
    • During reassembly, follow these instructions to reinstall a new webcam module:
    • Use tweezers to gently bend the webcam cable away from the screen frame.
    • Use your other hand to align the webcam module over the cable and lower it into place.
    • Make sure the webcam module sits level with the display before flipping down the cable locking tab and continuing reassembly.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,105 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 25
전체 시간: 666
