소개
In this guide, we will be taking apart the Fujifilm FinePix S4800 to remove and replace the flashbulb. This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera and removing the LCD screen. You will then be be able to remove and replace the flashbulb of your camera after removing a few more screw and desoldering the wires connected to the bulb.
필요한 것
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
Unsolder the connections shown in the image that connect the black, pink, white and blue wires to the bulb.
Soldering Guide: How To Solder and Desolder Connections
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
If it wasn't for this manual, I don't know how I would have figured it out. I am very lucky to be here
