주요 콘텐츠로 건너뛰기
Fujifilm FinePix S8630 Flashbulb Replacement
필요한 것
  1. Fujifilm FinePix S8630 Flashbulb Replacement, Battery Door: 1 단계, 이미지 1개 중 1개
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Flashbulb Replacement: 2 단계, 이미지 1개 중 1개
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Flashbulb Replacement: 3 단계, 이미지 1개 중 1개
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Flashbulb Replacement: 4 단계, 이미지 2개 중 1개 Fujifilm FinePix S8630 Flashbulb Replacement: 4 단계, 이미지 2개 중 2개
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Flashbulb Replacement: 5 단계, 이미지 1개 중 1개
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Flashbulb Replacement: 6 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flashbulb Replacement: 6 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flashbulb Replacement: 6 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Flashbulb Replacement: 7 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flashbulb Replacement: 7 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flashbulb Replacement: 7 단계, 이미지 3개 중 3개
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Flashbulb Replacement, LCD Screen: 8 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flashbulb Replacement, LCD Screen: 8 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flashbulb Replacement, LCD Screen: 8 단계, 이미지 3개 중 3개
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Flashbulb Replacement, Flashbulb: 9 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flashbulb Replacement, Flashbulb: 9 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flashbulb Replacement, Flashbulb: 9 단계, 이미지 3개 중 3개
  10. Fujifilm FinePix S8630 Flashbulb Replacement: 10 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flashbulb Replacement: 10 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flashbulb Replacement: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the tweezers remove the flashbulb.
결론
작성자
6다른 기여자 명과 함께
Colton Lancsarics
회원 가입일: 02/10/16
731 평판
안내서 6개를 작성함
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G2
4 회원들
안내서 12개를 작성함
1가이드 댓글
How do you discharge the capacitor on this model?
Flipping Turtle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 510
