주요 콘텐츠로 건너뛰기
Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement
필요한 것
  1. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 2 단계, 이미지 3개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 2 단계, 이미지 3개 중 2개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 2 단계, 이미지 3개 중 3개
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 4 단계, 이미지 3개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 4 단계, 이미지 3개 중 2개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, Lens: 5 단계, 이미지 1개 중 1개
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 6 단계, 이미지 3개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 6 단계, 이미지 3개 중 2개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 6 단계, 이미지 3개 중 3개
    • Pry off the center casing of the camera. Separate the top and side sections individually before fully removing the casing.
  7. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 9 단계, 이미지 3개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 9 단계, 이미지 3개 중 2개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 9 단계, 이미지 3개 중 3개
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 10 단계, 이미지 2개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 10 단계, 이미지 2개 중 2개
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
  11. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pull back the plastic covering the top of the camera.
  12. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 12 단계, 이미지 2개 중 1개 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 12 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect both the red and the black wires located next to the flash of the camera.
    • These wires will need to be soldered back in place upon reassembly.
  13. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 13 단계, 이미지 1개 중 1개
    • Pry off the top circuit board using the spudger.
  14. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 14 단계, 이미지 1개 중 1개
    • Use tweezers to disconnect the blue and white wires on the underside of the camera.
  15. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 15 단계, 이미지 1개 중 1개
    • Push the motherboard out of the camera body.
  16. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, Shutter and Power Button Circuit Board: 16 단계, 이미지 1개 중 1개
    • Desolder the red, black, and white wires from the circuit board that you pried off earlier.
    • You will have to solder these wires in the same locations on your replacement circuit board. Removing the motherboard makes accessing the wires easier and eliminates the risk of the motherboard being damaged from a soldering accident.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
George Lindner
회원 가입일: 01/20/15
252 평판
안내서 2개를 작성함
USF Tampa, Team 19-3, Blackwell Winter 2015 USF Tampa, Team 19-3, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 15
전체 시간: 658
