소개
Use this guide if the rear case is cracked or broken and needs to be replaced. Replacing the rear case requires removing plenty of screws which may prove difficult if they are stripped.
필요한 것
Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
Unlatch the four clasps located on each side of the camera by hand.
The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm FinePix XP50 Battery Replacement for instructions.
다른 한 분이 해당 안내서를 완성하였습니다.
