주요 콘텐츠로 건너뛰기
Fujifilm FinePix Z1 LCD Screen Replacement
필요한 것
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Fujifilm FinePix Z1 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Fujifilm FinePix Z1 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Fujifilm FinePix Z1 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Fujifilm FinePix Z1 LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Fujifilm FinePix Z1 LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
결론
작성자
2다른 기여자 명과 함께
Carra
회원 가입일: 01/30/18
533 평판
안내서 4개를 작성함
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G4
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 584
