주요 콘텐츠로 건너뛰기
GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement
필요한 것
  1. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 2개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 3개
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery: 2 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: 3 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, LCD Cover: 4 단계, 이미지 1개 중 1개
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Clock Radio: 5 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Clock Radio: 5 단계, 이미지 2개 중 2개
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Wires Wire Tie: 6 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Wires Wire Tie: 6 단계, 이미지 2개 중 2개
    • Using the wire cutters, carefully cut the plastic wire tie.
  7. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Speaker: 7 단계, 이미지 1개 중 1개
    • Grip the speaker.
    • Lift the speaker from the holder.
  8. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: 8 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: 8 단계, 이미지 2개 중 2개
    • Locate the two 6mm screws on the PCB.
    • Using a Phillips #0 Screwdriver, unscrew the two 6 mm screws from the PCB.
  9. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Switch Dial Screw: 9 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Switch Dial Screw: 9 단계, 이미지 2개 중 2개
    • Raise the PCB to expose the AM-FM switch dial screw.
    • Using a Phillip's #01 Screwdriver, unscrew the one 3mm screw from the middle of the AM-FM switch dial.
  10. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Pins: 10 단계, 이미지 3개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Pins: 10 단계, 이미지 3개 중 2개 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Pins: 10 단계, 이미지 3개 중 3개
    • Locate the AM-FM pins on the PCB.
    • Carefully apply the hot soldering iron to the solder on top of the AM-FM pins.
    • Gently and firmly push on the pins with the Spudger to remove the switch from the underside of the PCB.
결론
작성자
1다른 기여자 명과 함께
Dominick Giguere
회원 가입일: 10/28/14
848 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 1,243
