주요 콘텐츠로 건너뛰기
GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement
필요한 것
  1. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 2개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 3개
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery: 2 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Screws: 3 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Screws: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, LCD Cover: 4 단계, 이미지 1개 중 1개
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Clock Radio: 5 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Clock Radio: 5 단계, 이미지 2개 중 2개
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wires Wire Tie: 6 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wires Wire Tie: 6 단계, 이미지 2개 중 2개
    • Using the wire cutters, carefully cut the plastic wire tie.
  7. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Hot Melt Glue: 7 단계, 이미지 3개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Hot Melt Glue: 7 단계, 이미지 3개 중 2개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Hot Melt Glue: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Follow the wires to find where they connect to the printed circuit board (PCB). At the area of connect, two spots will be marked "DC+ and "DC-."
    • Apply the rubbing alcohol to the cotton swab end. Rub the end on the hot melt glue and wait for 30 seconds, then apply the alcohol to the hot melt glue again.
    • Use the tweezers to grab the softened hot melt glue. Pull the hot melt glue off of the clock radio.
  8. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Speaker: 8 단계, 이미지 1개 중 1개
    • Grip the speaker.
    • Lift the speaker from the holder.
  9. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Two Screws: 9 단계, 이미지 2개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Two Screws: 9 단계, 이미지 2개 중 2개
    • Locate the two 6mm screws on the PCB.
    • Using a Phillips #0 Screwdriver, unscrew the two 6 mm screws from the PCB.
  10. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wire Solder: 10 단계, 이미지 3개 중 1개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wire Solder: 10 단계, 이미지 3개 중 2개 GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wire Solder: 10 단계, 이미지 3개 중 3개
    • Raise the PCB.
    • With a ruler, measure 1.8 inches from the edge of the PCB. This solder is for the DC- battery wire connection.
    • Using a ruler, measure 9 mm from the edge of the PCB. This solder is for the DC+ battery wire connection.
  11. GE 7-4836B Alarm Clock AM-FM Radio Battery Wires Replacement, Battery Wires: 11 단계, 이미지 1개 중 1개
    • Apply the tip of the heated soldering iron to the DC- solder.
    • Pull the wire from the backside of the PCB DC-.
    • Apply the tip of the heated soldering iron to the DC+ solder.
    • Pull the wire from the backside of the PCB DC+.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominick Giguere
회원 가입일: 10/28/14
848 평판
안내서 6개를 작성함
1가이드 댓글
fuse resistence for mains supply for SL427 FM Radio and the same fuse resistence gets demaged frequently .....why?
Khurshid Ahmad - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 68
전체 시간: 1,901
