소개
Chip ID for the Samsung Galaxy S23 Ultra smartphone.
Check out our Samsung Galaxy S23 teardown for more details.
Many thanks to our community member CChin for his contributions!
동영상 개요
Qualcomm SM8550 64-bit octa-core Snapdragon applications/baseband processor layered underneath Micron MT62F1536M64D8CL-026 WT:B 12 GB LPDDR5 SDRAM memory
Samsung KLUFG8RHHD-B0G1 512 GB NAND flash memory w/ controller
Wacom WEZ02 digitizer controller
Cirrus Logic CS35L42 audio amplifier
Cirrus Logic CS40L26 haptic driver
Analog Devices MAX77705C power management
NXP Semiconductor PCA9481UK battery charger
Silicon Mitus SM3080I power management
Samsung S2MPBA3 power management
ConvenientPower CPS4038 40 W wireless power receiver w/ 10 W wireless power transmitter
Possibly Qualcomm envelope tracking power supply
Knowles MEMS microphone
Possibly Qualcomm power management
Possibly NXP Semiconductor load switch
Qualcomm WCN7851-101 FastConnect 7800 WiFi 7, 6, & 6E & Bluetooth 5.3 transceiver
NXP Semiconductor SR200T ? ultra-wideband transceiver
Qualcomm SDR735-001 RF transceiver
Qualcomm SMR546-002 RF transceiver
NXP Semiconductor SN220U ? NFC controller w/ secure element
STMicroelectronics STM32G051 ? 32-bit microcontroller
Qualcomm PMK8550 ? clock generator
Qualcomm PM8550VE-001 power management
Qualcomm PM8550VS-001 power management
Samsung S2MPB02 power management
Goertek MEMS Microphone
ETEK Microelectronics ET9902 over-voltage & surge protection
Kinetic Technologies over-voltage protection ?
NXP Semiconductor NVT4557HK SIM card interface level translator
Vishay DG2730 2-port DPDT analog switch
Diodes Incorporated AP7340D-30FS4-7 150 mA / 3.0 V LDO regulator
Qualcomm QPM7815-005 front end module
Qualcomm QPM6810-003 front end module
Maxscend MXDLN16GE GPS/GLONASS/Galileo/BeiDou low noise amplifier
Infineon BGSA20UGL8 dual SPST RF switch
Murata SAYRH634MBA0C0A band 71 SAW duplexer
Murata SAFFB722MAA0F0A band 29 SAW filter
Murata SAFFB2G45MA0F0A ISM 2.4G SAW filter
Murata SAFFB1G17AA0F0A GPS L5 SAW filter
Diodes Incorporated AH1897T ? hall sensor
Probably antenna switch
Wisol antenna switch module
Qualcomm antenna tuner
STMicroelectronics FJACJ ? touchscreen controller
Winbond W25Q80EWUXIE 1 MB serial NOR flash memory
Qualcomm QFS2630 ultrasonic fingerprint sensor
Qualcomm QBT2600-100 fingerprint sensor controller
댓글 7개
Correction: The S22 and prior use the CS35L40, while the S23 is using a seemingly customised part (CS35L42), there doesn't appear to be any kind of specs sheets available so I'm not sure if it's comparable to the CS35L45 in some of the other phones like the ROG, BlackShark, Xiaomi which have phenomenal sound systems.
is the Qualcomm WCN7851-101 FastConnect 7800 available worldwide or in US models only
Where is the camera hardware located?
Wasn't the S23 Ultra supposed to have LPDDR5x RAM?
Marcel Vos - 답글
Thank you so much..
