주요 콘텐츠로 건너뛰기
Game Boy Color Power LED Replacement
필요한 것
  1. Game Boy Color Power LED Replacement, Battery: 1 단계, 이미지 2개 중 1개 Game Boy Color Power LED Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Power LED Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Power LED Replacement, Back Housing: 3 단계, 이미지 1개 중 1개
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Power LED Replacement: 4 단계, 이미지 2개 중 1개 Game Boy Color Power LED Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Power LED Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Game Boy Color Power LED Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  6. Game Boy Color Power LED Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the motherboard from the front housing.
  7. Game Boy Color Power LED Replacement, Power LED: 7 단계, 이미지 2개 중 1개 Game Boy Color Power LED Replacement, Power LED: 7 단계, 이미지 2개 중 2개
  8. Game Boy Color Power LED Replacement: 8 단계, 이미지 1개 중 1개
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
  9. Game Boy Color Power LED Replacement: 9 단계, 이미지 1개 중 1개
    • Solder the leads of the new LED to the circuit board.
  10. Game Boy Color Power LED Replacement: 10 단계, 이미지 1개 중 1개
    • Cut the excess ends of the LED legs using the wire cutters.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alex Wu
회원 가입일: 01/11/13
1,664 평판
안내서 2개를 작성함
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 회원
CPSU-REGAN-W13S19G47
4 회원들
안내서 61개를 작성함
6가이드 댓글
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - 답글
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith -
and what kind of LED are you using to replace?
Soul Divide - 답글
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - 답글
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 106
전체 시간: 20,252
