주요 콘텐츠로 건너뛰기
Gardena EasyCut 9823 disassembly of lower part
필요한 것
  1. Gardena EasyCut 9823 disassembly of lower part, Gardena EasyCut 9823 disassembly of lower part: 1 단계, 이미지 1/1
    • Unscrew the three visible screws, surrounded in red in picture.
  2. Gardena EasyCut 9823 disassembly of lower part: 2 단계, 이미지 1/1
    • Remove the two black covers. Frankly, there is no click system.
  3. Gardena EasyCut 9823 disassembly of lower part: 3 단계, 이미지 1/1
    • Remove black protection against grass. Do that by rotating it. Rotation is blocked at two places that you can press with a thin screwdriver.
  4. Gardena EasyCut 9823 disassembly of lower part: 4 단계, 이미지 1/3 Gardena EasyCut 9823 disassembly of lower part: 4 단계, 이미지 2/3 Gardena EasyCut 9823 disassembly of lower part: 4 단계, 이미지 3/3
    • Remove the 6 screws now visible in the blue part. Open it in two parts.
  5. Gardena EasyCut 9823 disassembly of lower part: 5 단계, 이미지 1/1
    • Pull out white block and engine. Then split white block in two by pulling at the arrow place on provided picture.
  6. Gardena EasyCut 9823 disassembly of lower part: 6 단계, 이미지 1/1
    • Clean, fix and re-protect damaged connector.
결론
In order to reassemble your device, please follow instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Bossard Nicolas
회원 가입일: 09/21/18
1,197 평판
안내서 6개 작성하였습니다
댓글 6개
Thanks a lot! My trimmer had the exact same problem.
trrttsch - 답글
Das gleiche Problem bei 2 Trimmern. Danke, die Anleitung hat sehr geholfen!
Martin Kammerhofer - 답글
Ich hatte das gleiche Problem: ein Draht abgebrochen.
Dannk dieser professionellen Anleitung funktioniert der Rasentrimmer wieder. Ohne diese hätte ich es nicht geschafft, den Grasfangteller zu demontieren
Manfred Schierhuber - 답글
Wo bekommt man einen neuen Motor her
Ulli Leistner - 답글
Da müssen Sie sich wohl an den Hersteller wenden!
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 61
30일 전: 259
전체 시간: 7,451
