필요한 것
Use a the end of a flat screwdriver, lever out the cover and put it aside.
Insert a small flat end screw driver into the notch of the central axis.
Tightly hold in place the screwdriver with one hand and spin the plate with the other. The bolt is held in the plastic plate and will unscrew with it.
To reassemble your device, follow the instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Bonjour Comment retirez-vous le disque quand le boulon est retiré? Mon disque reste coincé dans l'appareil.
Humm chez moi il vient tout seul une fois le boulon enlevé. Désolé pas de suggestion.
