주요 콘텐츠로 건너뛰기
Garmin Nüvi 205W LCD Display Replacement
필요한 것
  1. Garmin Nüvi 205W LCD Display Replacement, LCD Display: 1 단계, 이미지 1/3 Garmin Nüvi 205W LCD Display Replacement, LCD Display: 1 단계, 이미지 2/3 Garmin Nüvi 205W LCD Display Replacement, LCD Display: 1 단계, 이미지 3/3
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
  2. Garmin Nüvi 205W LCD Display Replacement: 2 단계, 이미지 1/3 Garmin Nüvi 205W LCD Display Replacement: 2 단계, 이미지 2/3 Garmin Nüvi 205W LCD Display Replacement: 2 단계, 이미지 3/3
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
  3. Garmin Nüvi 205W LCD Display Replacement: 3 단계, 이미지 1/3 Garmin Nüvi 205W LCD Display Replacement: 3 단계, 이미지 2/3 Garmin Nüvi 205W LCD Display Replacement: 3 단계, 이미지 3/3
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
  4. Garmin Nüvi 205W LCD Display Replacement: 4 단계, 이미지 1/3 Garmin Nüvi 205W LCD Display Replacement: 4 단계, 이미지 2/3 Garmin Nüvi 205W LCD Display Replacement: 4 단계, 이미지 3/3
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
  5. Garmin Nüvi 205W LCD Display Replacement: 5 단계, 이미지 1/3 Garmin Nüvi 205W LCD Display Replacement: 5 단계, 이미지 2/3 Garmin Nüvi 205W LCD Display Replacement: 5 단계, 이미지 3/3
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
  6. Garmin Nüvi 205W LCD Display Replacement: 6 단계, 이미지 1/3 Garmin Nüvi 205W LCD Display Replacement: 6 단계, 이미지 2/3 Garmin Nüvi 205W LCD Display Replacement: 6 단계, 이미지 3/3
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
784,351 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 560개 작성하였습니다
댓글 2개
After reinstalling LCD screen how do I reconnect the ribbon cable? Any tips would be GREATLY appreciated :) Thank You
John - 답글
Thank you! Saved me a new GPS!
worthless0000 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 3,354
