주요 콘텐츠로 건너뛰기
Garmin Nüvi 370 Battery Replacement
필요한 것
  1. Garmin Nüvi 370 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nüvi 370 Battery Replacement: 2 단계, 이미지 1/3 Garmin Nüvi 370 Battery Replacement: 2 단계, 이미지 2/3 Garmin Nüvi 370 Battery Replacement: 2 단계, 이미지 3/3
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nüvi 370 Battery Replacement: 3 단계, 이미지 1/2 Garmin Nüvi 370 Battery Replacement: 3 단계, 이미지 2/2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nüvi 370 Battery Replacement: 4 단계, 이미지 1/2 Garmin Nüvi 370 Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Garmin Nüvi 370 Battery Replacement: 5 단계, 이미지 1/2 Garmin Nüvi 370 Battery Replacement: 5 단계, 이미지 2/2
    • Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
  6. Garmin Nüvi 370 Battery Replacement: 6 단계, 이미지 1/1
    • The battery should now be completely separated from the other components.
    • Insert new, functional battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
poopspeedstream
회원 가입일: 04/19/13
1 평판
안내서 1개 작성함
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G65
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 10
전체 시간: 1,797
