주요 콘텐츠로 건너뛰기
Garmin Nüvi 370 Speaker Replacement
필요한 것
  1. Garmin Nüvi 370 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nüvi 370 Speaker Replacement: 2 단계, 이미지 1/3 Garmin Nüvi 370 Speaker Replacement: 2 단계, 이미지 2/3 Garmin Nüvi 370 Speaker Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nüvi 370 Speaker Replacement: 3 단계, 이미지 1/2 Garmin Nüvi 370 Speaker Replacement: 3 단계, 이미지 2/2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nüvi 370 Speaker Replacement: 4 단계, 이미지 1/3 Garmin Nüvi 370 Speaker Replacement: 4 단계, 이미지 2/3 Garmin Nüvi 370 Speaker Replacement: 4 단계, 이미지 3/3
    • Detach blue speaker cable from motherboard.
    • Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
  5. Garmin Nüvi 370 Speaker Replacement: 5 단계, 이미지 1/2 Garmin Nüvi 370 Speaker Replacement: 5 단계, 이미지 2/2
    • Detach speaker from casing and insert new, functional speaker.
    • Battery is removed in the picture and is not required for the installation of a new speaker.
결론
Matt West
회원 가입일: 04/18/13
31 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G65
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 316
