소개
In this guide the repairer replaces the speaker of the device by disassembling the device further to expose the motherboard and speaker.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
부품
No parts specified.
  1. After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. The motherboard will now freely separate from the back casing; lay it flat next to the housing. The motherboard will now freely separate from the back casing; lay it flat next to the housing.
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  5. Detach blue speaker cable from motherboard. Battery cable is detached in this picture, and it is not required to do so to install a new speaker. Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
    • Detach blue speaker cable from motherboard.
    • Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
  6. Detach speaker from casing and insert new, functional speaker. Battery is removed in the picture and is not required for the installation of a new speaker.
    • Detach speaker from casing and insert new, functional speaker.
    • Battery is removed in the picture and is not required for the installation of a new speaker.
결론
Matt West
회원 가입일: 2013년 04월 18일
22 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G65
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 257
