소개
Problems with charging the battery? Is the USB port damaged where it is no longer able to plug into the charging cable? It might be time to replace your USB port. After removing the second frame panel be sure to read the Cautions and steps thoroughly before proceeding.
필요한 것
Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
I found one on ebay, cost about 5 USD. Search for micro USB jack.
Heliophile - 답글
those are not micro usb, there mini usb.
Did I miss something? The title implies showing how to REPLACE the port. It ends with remove port and set aside, then reverse. On the off-chance the authors are still reading the comments, sarcastic “good job”. I also marvel that it took three of you geniuses to come up with this. I’m gonna follow Heliophile’s advice and search ebay, his or her 2 line comment was way more useful then the entire piece. Thanks Heliophile.
