주요 콘텐츠로 건너뛰기
Garmin Nuvi 2455LMT Mother Board Replacement
필요한 것
  1. Garmin Nuvi 2455LMT Mother Board Replacement, Back Panel Assembly: 1 단계, 이미지 1/1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Mother Board Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 2455LMT Mother Board Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Mother Board Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 2455LMT Mother Board Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 2455LMT Mother Board Replacement: 3 단계, 이미지 3/3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Mother Board Replacement, Mother Board: 4 단계, 이미지 1/1
    • Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
    • Hold the GPS with a free hand to ensure stability.
  5. Garmin Nuvi 2455LMT Mother Board Replacement: 5 단계, 이미지 1/2 Garmin Nuvi 2455LMT Mother Board Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Place the screen portion of the GPS face down.
    • Remove the mother board from the plastic back panel.
    • Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
  6. Garmin Nuvi 2455LMT Mother Board Replacement: 6 단계, 이미지 1/1
    • Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
결론
Nathaniel Williams
회원 가입일: 09/19/16
264 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 542
