주요 콘텐츠로 건너뛰기
Garmin Nuvi 2589LMT Microphone Replacement
필요한 것
  1. Garmin Nuvi 2589LMT Microphone Replacement, Back Panel Assembly: 1 단계, 이미지 1/1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Microphone Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 2589LMT Microphone Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Microphone Replacement, Microphone: 3 단계, 이미지 1/1
    • Using a soldering iron, desolder the wire connection at the two soldering points between the microphone and the motherboard to remove.
    • Learn more about soldering and desoldering connections here.
  4. Garmin Nuvi 2589LMT Microphone Replacement: 4 단계, 이미지 1/1
    • Using the angled tweezers, grab the microphone wires and gently pull to remove the microphone from the device.
결론
Adam Ferraro
회원 가입일: 10/04/16
920 평판
안내서 8개 작성하였습니다
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016 회원
USFT-NANCE-F16S1G2
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Where do you buy the new microphone?
Rich Hollabaugh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 583
