소개
Before replacing the battery, visit the device's troubleshooting page to determine whether you need to replace the battery. Follow the steps in this guide if you need to replace the battery.
필요한 것
Place the GPS face down on a flat surface.
Make sure the side containing the speaker and charging port is facing up.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 5개
The process really is as essy as it looks. One thing though...
It seemed as though something would break before the battery would release. Not to worry; hold the case securely and the battery will eventually pop loose.
Great instructions, thanks. What helped me get the battery loose was to hit the outside of the case where the battery was with a hair dryer on high heat for about 4 minutes, then use a small flat-blade screwdriver under the battery corner, next to where the speaker is housed. It’s tempting to insert the pry tool between the battery and the thin “walls” that surround it, but the walls bent with slight pressure, so don’t do it!
thanks Maurice, very helpful.
The hardest part was removing the cover. I didn’t have the plastic tool but managed, eventually.
Also the battery was a challenge, as previously noted in prior comment.
It is installed with powerful twin stick tape, so was able to pry it out along the perimeter, to loosen it up.
