이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Use a Phillips #00 screwdriver to remove the four screws around the screen.
Gently pull from both ends of the casing to separate the front and back panels.
Gently unplug the white cable connector using either your fingers or tweezers.
Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
Carefully peel the metal bracket away from the battery.
Pull the battery away from the back cover.
Desolder the wires from the speakers using a soldering iron.
Carefully use the spudger to pry the speakers from the outer casing.
Once removed, you may use a soldering iron to remove the wires from the speakers.
