주요 콘텐츠로 건너뛰기
Garmin Vivoactive Motherboard Replacement
필요한 것
  1. Garmin Vivoactive Motherboard Replacement, Wristband: 1 단계, 이미지 1/1
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
  2. Garmin Vivoactive Motherboard Replacement: 2 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement: 2 단계, 이미지 2/2
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
  3. Garmin Vivoactive Motherboard Replacement, Display Unit: 3 단계, 이미지 1/1
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
  4. Garmin Vivoactive Motherboard Replacement: 4 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement: 4 단계, 이미지 2/2
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
  5. Garmin Vivoactive Motherboard Replacement: 5 단계, 이미지 1/1
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
  6. Garmin Vivoactive Motherboard Replacement: 6 단계, 이미지 1/1
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
  7. Garmin Vivoactive Motherboard Replacement: 7 단계, 이미지 1/1
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
  8. Garmin Vivoactive Motherboard Replacement: 8 단계, 이미지 1/1
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
  9. Garmin Vivoactive Motherboard Replacement, Battery: 9 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement, Battery: 9 단계, 이미지 2/2
    • Follow previous guides until you've exposed the battery as shown.
    • Begin by removing the battery connector tab.
    • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
  10. Garmin Vivoactive Motherboard Replacement: 10 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening pick to gently pry out the battery as shown.
    • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
  11. Garmin Vivoactive Motherboard Replacement: 11 단계, 이미지 1/3 Garmin Vivoactive Motherboard Replacement: 11 단계, 이미지 2/3 Garmin Vivoactive Motherboard Replacement: 11 단계, 이미지 3/3
    • With the battery loose from the case, rotate it to expose the attached tab
    • Gently pry up the attached tab with a fingernail.
    • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
  12. Garmin Vivoactive Motherboard Replacement, Motherboard: 12 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement, Motherboard: 12 단계, 이미지 2/2
    • Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
    • Make an effort not to damage any nearby components of the motherboard with the screwdriver.
  13. Garmin Vivoactive Motherboard Replacement: 13 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement: 13 단계, 이미지 2/2
    • Use the spudger to pry up the board from the case.
    • Insert the spudger a minimum distance beneath the board as there are components below.
    • Wiggle the exposed side of the board from each end until it comes free.
    • Use proper electrostatic discharge safety when removing and handling the board.
  14. Garmin Vivoactive Motherboard Replacement: 14 단계, 이미지 1/2 Garmin Vivoactive Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the GPS antenna by sliding it away from the board.
    • Keep track of the antenna and add it to the new board upon replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tessa Gunnin
회원 가입일: 10/01/15
466 평판
안내서 2개 작성하였습니다
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 회원
CPSU-MANESS-F15S1G21
4 회원들
안내서 17개 작성하였습니다
댓글 2개
Any tips on where to buy a motherboard?
Breener - 답글
Only <3 months, the motherboard is gone?
Do you have any service shop where I can mail for repairing? I am not going to mail order a motherboard and install by myself every 3 months.
Ming
Yong-Ming Yu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 28
전체 시간: 14,148
