주요 콘텐츠로 건너뛰기
Garmin inReach Explorer Plus Button Pad Replacement
필요한 것
  1. Garmin inReach Explorer Plus Button Pad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus Button Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover.
  3. Garmin inReach Explorer Plus Button Pad Replacement: 3 단계, 이미지 2개 중 1개 Garmin inReach Explorer Plus Button Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus Button Pad Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Garmin inReach Explorer Plus Button Pad Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus Button Pad Replacement: 5 단계, 이미지 2개 중 1개 Garmin inReach Explorer Plus Button Pad Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus Button Pad Replacement: 6 단계, 이미지 2개 중 1개 Garmin inReach Explorer Plus Button Pad Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus Button Pad Replacement: 7 단계, 이미지 3개 중 1개 Garmin inReach Explorer Plus Button Pad Replacement: 7 단계, 이미지 3개 중 2개 Garmin inReach Explorer Plus Button Pad Replacement: 7 단계, 이미지 3개 중 3개
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus Button Pad Replacement, Button Pad: 8 단계, 이미지 3개 중 1개 Garmin inReach Explorer Plus Button Pad Replacement, Button Pad: 8 단계, 이미지 3개 중 2개 Garmin inReach Explorer Plus Button Pad Replacement, Button Pad: 8 단계, 이미지 3개 중 3개
    • After the motherboard is removed, make sure the wire is out of the way of the button pad.
    • Flip the device over and push down on the button pad to remove it from the device.
결론
작성자
1다른 기여자 명과 함께
Sean Kelley
회원 가입일: 09/28/21
387 평판
안내서 4개를 작성함
Clemson, Team 5-4, Hunter Fall 2021 Clemson, Team 5-4, Hunter Fall 2021 회원
CLEM-HUNTER-F21S5G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 294
