주요 콘텐츠로 건너뛰기
Gateway NE56R Series Hard Drive Replacement
필요한 것
  1. Gateway NE56R Series Hard Drive Replacement, Remove hard drive cover: 1 단계, 이미지 2개 중 1개 Gateway NE56R Series Hard Drive Replacement, Remove hard drive cover: 1 단계, 이미지 2개 중 2개
    • Remove the two Philips screws securing the hard drive cover to the base.
    • Pry the hard drive cover off with a spudger.
  2. Gateway NE56R Series Hard Drive Replacement, Remove hard drive caddy: 2 단계, 이미지 1개 중 1개
    • With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
  3. Gateway NE56R Series Hard Drive Replacement, Remove hard drive: 3 단계, 이미지 1개 중 1개
    • This step is unnecessary if you are only taking the hard drive out for testing purposes or are removing the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Sctbunio
회원 가입일: 09/23/17
7,527 평판
안내서 42개를 작성함
댓글 2개
Very helpful now I need to know how to replace the mother board from the same machine as the Hard drive.
Michael K - 답글
Does replacement of harddrive effect memory?
Nathaniel TRotter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 1,859
