Gateway NE56R Series Hard Drive Replacement
This guide teaches you how to replace the hard drive in a Gateway NE series laptop.
Remove the two Philips screws securing the hard drive cover to the base.
Pry the hard drive cover off with a spudger.
With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
다른 2명이 해당 안내서를 완성하였습니다.
2가이드 댓글
Does replacement of harddrive effect memory?
