주요 콘텐츠로 건너뛰기
Gateway W350I Display Replacement
필요한 것
  1. Gateway W350I Display Replacement, Battery Access: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 1개 Gateway W350I Display Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 2개 Gateway W350I Display Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 3개
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 3 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 3 단계, 이미지 2개 중 2개
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
    These pictures look like they might be out of order. The second picture looks like the screw has been removed.
    Proofread the text in the first bullet point of this step.
    I don't see the rubber protectors that you mention.
    Dan Brown - 답글
  4. Gateway W350I Display Replacement, Separate Plastic Casing: 4 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Separate Plastic Casing: 4 단계, 이미지 2개 중 2개
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
    I'm not quite sure what I'm supposed to be seeing in the second picture. Where/what are the clip connectors that you mention?
    Dan Brown - 답글
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 5 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 5 단계, 이미지 2개 중 2개
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: 6 단계, 이미지 1개 중 1개
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: 7 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Remove Video Cable: 7 단계, 이미지 2개 중 2개
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
    I could use clarification as to why steps 7 and 8 are here. The introduction suggests that this guide shows how to replace the screen, so why would I need to do these as well?
    Dan Brown - 답글
  8. Gateway W350I Display Replacement: 8 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the camera connector from the circuit board to completely free the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Samuel Newton
회원 가입일: 09/22/14
308 평판
안내서 1개를 작성함
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 회원
USFT-BROWN-F14S4G1
3 회원들
안내서 10개를 작성함
1가이드 댓글
It was very easy to follow.
Very friendly guide.
Stephan Williams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 1,341
