주요 콘텐츠로 건너뛰기
GermGuardian AC4825E UV-C Bulb Replacement
필요한 것
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: 1 단계, 이미지 1개 중 1개
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: 2 단계, 이미지 2개 중 1개 GermGuardian AC4825E UV-C Bulb Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: 3 단계, 이미지 3개 중 1개 GermGuardian AC4825E UV-C Bulb Replacement: 3 단계, 이미지 3개 중 2개 GermGuardian AC4825E UV-C Bulb Replacement: 3 단계, 이미지 3개 중 3개
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: 4 단계, 이미지 1개 중 1개
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: 5 단계, 이미지 3개 중 1개 GermGuardian AC4825E UV-C Bulb Replacement: 5 단계, 이미지 3개 중 2개 GermGuardian AC4825E UV-C Bulb Replacement: 5 단계, 이미지 3개 중 3개
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tim Lourenco
회원 가입일: 03/28/22
329 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-1, Mellen Spring 2022 UMass Dartmouth, Team 2-1, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S2G1
4 회원들
안내서 2개를 작성함
1가이드 댓글
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 63
전체 시간: 2,989
