이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 2개
Where can you get replacement rear screens for this
