주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero5 Black Lens Assembly Replacement
필요한 것
    1. GoPro Hero5 Black Lens Assembly Replacement, Battery: 1 단계, 이미지 3개 중 1개 GoPro Hero5 Black Lens Assembly Replacement, Battery: 1 단계, 이미지 3개 중 2개 GoPro Hero5 Black Lens Assembly Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
      댓글 쓰기
    2. GoPro Hero5 Black Lens Assembly Replacement: 2 단계, 이미지 3개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 2 단계, 이미지 3개 중 2개 GoPro Hero5 Black Lens Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • Grab the plastic flap on the battery and pull the battery out.
      댓글 쓰기
    1. GoPro Hero5 Black Lens Assembly Replacement, Back Housing: 3 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement, Back Housing: 3 단계, 이미지 2개 중 2개
      • Pull and twist the lens cover right or left until it pops off.
      • The lens cover is secured tightly and might be difficult to twist off.
      댓글 쓰기
    2. GoPro Hero5 Black Lens Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • This step is not necessary but will make the process of removing the faceplate much easier.
      • Refer to the iOpener instructions for how to heat up and use the iOpener.
      • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
      • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
      댓글 쓰기
    3. GoPro Hero5 Black Lens Assembly Replacement: 5 단계, 이미지 3개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 5 단계, 이미지 3개 중 2개 GoPro Hero5 Black Lens Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Starting with the edges, use the spudger to pry off the faceplate.
      • The faceplate is held down with adhesive and may take a while to get off.
      댓글 쓰기
    4. GoPro Hero5 Black Lens Assembly Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the six T3 Torx screws.
      댓글 쓰기
    5. GoPro Hero5 Black Lens Assembly Replacement: 7 단계, 이미지 3개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 7 단계, 이미지 3개 중 2개 GoPro Hero5 Black Lens Assembly Replacement: 7 단계, 이미지 3개 중 3개
      • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
      • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
      댓글 쓰기
    6. GoPro Hero5 Black Lens Assembly Replacement: 8 단계, 이미지 3개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 8 단계, 이미지 3개 중 2개 GoPro Hero5 Black Lens Assembly Replacement: 8 단계, 이미지 3개 중 3개
      • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
      댓글 쓰기
    7. GoPro Hero5 Black Lens Assembly Replacement: 9 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 9 단계, 이미지 2개 중 2개
      • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
      댓글 쓰기
    1. GoPro Hero5 Black Lens Assembly Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
      댓글 쓰기
    2. GoPro Hero5 Black Lens Assembly Replacement: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
      댓글 쓰기
    3. GoPro Hero5 Black Lens Assembly Replacement: 12 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the two #000 Phillips screw.
      댓글 쓰기
    4. GoPro Hero5 Black Lens Assembly Replacement: 13 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 13 단계, 이미지 2개 중 2개
      • Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
      • Once the ribbon cable is disconnected from the motherboard. The charging port assembly should come right off.
      댓글 쓰기
    5. GoPro Hero5 Black Lens Assembly Replacement: 14 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the 10mm #000 Phillips screw.
      댓글 쓰기
    6. GoPro Hero5 Black Lens Assembly Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the charging assembly housing by pulling it straight up off the motherboard.
      댓글 쓰기
    7. GoPro Hero5 Black Lens Assembly Replacement: 16 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the two 6mm #000 Phillips screws.
      • Remove the two 2mm #000 Phillips screws.
      댓글 쓰기
    8. GoPro Hero5 Black Lens Assembly Replacement: 17 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
      댓글 쓰기
    9. GoPro Hero5 Black Lens Assembly Replacement: 18 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
      댓글 쓰기
    10. GoPro Hero5 Black Lens Assembly Replacement: 19 단계, 이미지 3개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 19 단계, 이미지 3개 중 2개 GoPro Hero5 Black Lens Assembly Replacement: 19 단계, 이미지 3개 중 3개
      • Use the flat end of the spudger to pry the motherboard off the midframe.
      • The motherboard is held onto the midframe with light adhesive and should come right off with a little force.
      댓글 쓰기
    1. GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: 20 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: 20 단계, 이미지 2개 중 2개
      • Remove the 2mm #000 Phillips screws using a #000 Phillips head screwdriver or tool bit.
      댓글 쓰기
    2. GoPro Hero5 Black Lens Assembly Replacement: 21 단계, 이미지 2개 중 1개 GoPro Hero5 Black Lens Assembly Replacement: 21 단계, 이미지 2개 중 2개
      • Pull the lens assembly straight out from the Midframe.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christopher Adams
회원 가입일: 10/03/16
2,133 평판
안내서 5개를 작성함
Cal Poly, Team 18-6, Forte Fall 2016 Cal Poly, Team 18-6, Forte Fall 2016 회원
CPSU-FORTE-F16S18G6
4 회원들
안내서 22개를 작성함
7가이드 댓글
RageCams has interchangeable lens mod for hero5
http://ragecams.com/shop/modified-gopro-...
dennis - 답글 공유
why can't You show how the lens is mount to that assembly? That's the point of it... can we change lenses that way or not?
Polina Luzenco - 답글 공유
Exactly. Can the actual lens be unscrewed from the mount or it glued / fixed?
contact - 답글 공유
The lens is heavily glued onto the assembly. It would be far easier to replace the entire assembly than trying to remove that glue.
Christopher Adams - 답글 공유
the guy who wrote the guide apparently has never heard of pliers. it comes right out, but no idea what the threading is.
mattatron4 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 20
지난 30일: 80
전체 시간: 17,918
