주요 콘텐츠로 건너뛰기
Google Home Hub 1st Generation I/O Daughter Board Replacement
필요한 것
  1. Google Home Hub 1st Generation I/O Daughter Board Replacement, I/O Daughter Board: 1 단계, 이미지 1/3 Google Home Hub 1st Generation I/O Daughter Board Replacement, I/O Daughter Board: 1 단계, 이미지 2/3 Google Home Hub 1st Generation I/O Daughter Board Replacement, I/O Daughter Board: 1 단계, 이미지 3/3
    • Using a blue opening tool, work your way around the perimeter of the rubber foot, prying along the way until the adhesive releases.
    • Be careful not to warp the speaker housing with excessive force.
    • After the adhesive is broken, simply remove the rubber foot with your fingers.
  2. Google Home Hub 1st Generation I/O Daughter Board Replacement: 2 단계, 이미지 1/1
    • With your T5 screwdriver, unscrew the 2 silver, 5.4mm screws.
  3. Google Home Hub 1st Generation I/O Daughter Board Replacement: 3 단계, 이미지 1/2 Google Home Hub 1st Generation I/O Daughter Board Replacement: 3 단계, 이미지 2/2
    • Grasp the IO daughter board ribbon between your thumb and pointer finger, then gently pull up and toward the display to unseat the ribbon cable.
  4. Google Home Hub 1st Generation I/O Daughter Board Replacement: 4 단계, 이미지 1/2 Google Home Hub 1st Generation I/O Daughter Board Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • With your fingernail or tweezers, flip the clip up ninety-degrees, so it's standing perpendicular to the IO daughter board.
  5. Google Home Hub 1st Generation I/O Daughter Board Replacement: 5 단계, 이미지 1/2 Google Home Hub 1st Generation I/O Daughter Board Replacement: 5 단계, 이미지 2/2
    • Grip the ribbon cable near the port with round-tip tweezers, and pull directly backwards, parallel to the board, to disconnect the ribbon cable. You can also use your fingers if you don't want to grab your tweezers.
결론
Connor Bassolino
회원 가입일: 03/29/22
8,140 평판
안내서 42개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,869개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 37
전체 시간: 232
