이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
이 단계에 사용된 도구:Magnetic Project Mat$19.95-
Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
Remove the following screws securing the midframe:
Eleven 3.7 mm Phillips screws
One 4 mm T5 Torx screw
Insert an opening tool into the notch in the midframe near the hold button.
Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
Lift the midframe up starting from the bottom edge.
When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
