주요 콘텐츠로 건너뛰기
Google Pixel 9 5G mmWave Antenna Replacement
필요한 것
  1. Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 3개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 2개
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 5G mmWave Antenna Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 5G mmWave Antenna Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement: 7 단계, 이미지 3개 중 3개
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 5G mmWave Antenna Replacement, Remove the back glass: 8 단계, 이미지 1개 중 1개
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 5G mmWave Antenna Replacement, Remove the upper board cover: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 5G mmWave Antenna Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement: 10 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: 11 단계, 이미지 1개 중 1개
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: 12 단계, 이미지 2개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: 12 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: 13 단계, 이미지 2개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: 13 단계, 이미지 2개 중 2개
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: 15 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: 15 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: 15 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  16. Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: 16 단계, 이미지 3개 중 1개 Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: 16 단계, 이미지 3개 중 2개 Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: 16 단계, 이미지 3개 중 3개
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
결론
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
작성자
1다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,196 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,589개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 37
지난 30일: 165
전체 시간: 2,488
